Couple issues that I’m having
What I’m expecting with the dome light & z-depth pass:
- Dome light; when affect alpha is turned off, the image should still show - but the alpha will not be affected. Currently the image turns to black while not affecting the alpha.
- The z-depth pass, I’d expect that if the background color is visible anywhere, it would give me a color to match the furthest distance. At the moment it’s showing me the color of whatever is closest - so an inverted zdepth goes from white (foreground) to black, and then the empty space is returning as white…
Is this right? Maybe there’s something I screwed up somewhere?
I’m using vray 3.00.02
update: included .max file in link above
I installed 3.00.03 and opened this max file and still had the issue - but when I started a fresh scene the depth pass was working correctly. Still had the dome image turning black when affect alpha was unticked.
update2: depth info seems to be totally an issue with 3.00.02 - going back to this version I start a new scene and have immediate depth issues with the background. This issue seems to carry over when opened in the new version - but I suppose the old scene could be merged into a new one to resolve this?
thanks
Thank you very much for your feedback.
It seams that you are right - there is something wrong with the Depth in the scene you sent us - was it created with 3.00.02 ?
Could you please try to remove VrayZDepth element and add it again - it seams that it works fine here after that operation at least in 3.00.03.
According to the Dome Light affect alpha issue - I am going to report it in our database and I’ll update this thread when we have fix about it.
Svetlozar,
Thanks for the response - the issue was resolved by removing the element and replacing it with a new one. (3.00.02)
The element must have been quite old, revived from an old project.
edit: just tested the test.max file in v-ray 2.4, no issue with the depth pass. still not sure when the pass was originally created or what version - but it seems to break when jumping to v-ray 3.0
It could be from the beta-version as well.
If you could find out from which version it comes we could pass the case to our devs for further investigation.
Hello, cheerioboy
We would like to inform you that affect-alpha issue has been fixed.
The fix is only available in the Nightly builds for the moment.
Thank you very much for your feedback again.
great work, thanks Svetlozar
