Z-Depth Masking and Levels Correction
Hi Chaosgroup,
can we have VFB Display Correction with Z-Depth Masking, and also Levels correction.
or maybe i missed something?
if there is. I think this would fully swap out the Photoshop editing procedure. makeing renderings as good as the final image.
Thanks for the ideas :slight_smile:
- VFB Display Correction with Z-Depth Masking - can you give some examples of how you are using the Z-Depth ?
- Levels correction - you should be able to use the Curves correction instead of the Levels ?
Yavor
