I seem to be having a problem saving out a Z-Depth map in Vray 1.50.
I set up the Z-Depth the same as all the other render elements, but whilst the other elements render fine, the Z-Depth just renders completely black.
I have rendered using different file types, both hi and low dynamic ranges, both with a standard camera and the new V-ray physical camera, and I have made sure that I haven’t got anything very close or very far away from the camera which might through out the range vale. But no luck.
Any help would be appreciated.
