ZDepth render layer not showing up in Nuke
I am having an issue with zdepth passes not showing up in Nuke. If I save out a multichannel exr from the render buffer and bring it into Nuke the depth pass is there as expected. Once the scene is submitted to Deadline and I bring the sequence into Nuke the depth pass is empty.
We are rendering out a 16bit multichannel exr with Maya 2018 and VRay Next. Our Nuke version is 10.5v7.
Any help with this matter would be greatly appreciated.
Thank you!
I can’t manage to reproduce this behavior. Can you attach a simple scene? Does it only happen with a particular scene?
Please unchek multi-part exr and try again.
Hi Dmitry,
Thank you! That solved the problem. Is this a bug or intended behavior? We didn’t have this issue with previous versions of VRay.
I am not sure, I had issues with multi-part exr reading in older nuke versions at all.
I have the same issue. How it’s possible then, to get multiple channels in one exr when it is not rendered as a multiExr?
thanks
multi-part exr and multichannel exr are different things. I think multi-part is used to optimize the pixels in different channels you do not need to use multi-part to get multichannel exr.
Ok thanks,
I found now the thread I need :wink:
