ZDepth
I can’t seem to get my ZDepth to work under 1.5. I have a sphere placed 200’ from the camera and a box around 12’. What should my min/max be? I a also having issues with DOF… doesn’t seem to work either. Any tips?
I normally turn on the environment ranges of my camera and then use the near and far lines that it draws as a way to work out what values to use as my start and end. Do it visually so it covers the range you need i your viewports then put those values into the render dialog.
