Zipper Bugs list
follwing the overall idea here im doing my thread for stuff i find :smiley:
so to start off:
alpha v2
  • corona ignores “render iterations” in turbosmooth modifiers
    _Keymaster: FIXED
  • crash on adding map to emitter slot
    _Keymaster: FIXED
  • i had some crashes on changing path tracing back and forth but cant replicate that for now.
Assigning a map to CoronaMtl Emission slot causes 3dsmax crash.
Yes, i found that bug too.
Even in Alpha v.3
there is no alpha v3 :wink:
ok, one more thing:
if you render out animation sequence the .hdr files are black (both from corona vfb and normal max vfb). .png save fine.
but the .hdr render passes seem to be ok?
and one more: corona seems to ignore modifiers set to invisible in viewport (visible on render) probably same problem as rendering subdivs in turbosmooth.
_Keymaster: FIXED
Im using EXR and i had blank/black image too but when saving EXR, switch to full float and not to integer
yeah, full exr works fine :smiley:
and new bug report:
displacement on instances breaks horribly, scene on drop:
https://dl.dropbox.com/u/108014/displace_bug.zip
I’ve fixed some, for the HDR saving stuff I’ll probably have to contact autodesk
