zoom limit?
This may sound silly, but when in perspective view, why does max stop zooming at a certain point? It’s very annoying, because I want to zoom in closer to look at some part of the scene, but before I get close enough, zoom just stops zooming?! I have been plagued by this in max 6-7-8-9…
I usually have to select something nearby and press z, but this is not always a possible work-around. Anyone have any ideas or know what setting might deal with this? Thanks in advance
use the “user” viewport instead of perspective.
Thanks Jonas, I’ll try that.
thanks Jonas, it works better
nice. :slight_smile:
The problem is your unit setup.
I already had this kind of problem when I work in meter, in cm it doesn’t appear.
So does this mean if I need to work in decimal inches, I will always face this problem?
I never work in inche of course(FR), but if your unit are too big, when you zoom there is a kind of clipping.
That what I have seen.
Thanks priad, this makes sense. Sometimes it does seem to clip my view, but it seems sort of random. i guess for the moment I will stick with user view or try Generic Units.
its not in the unit setup. that problem with the zoom limit is that your perspective “camera” has reach the same position as your perspective “target”.
you can check by hitting CTRL+C in pespective view. there you will see what i mean.
/Ryan
Hi /Ryan
Thank you. I tried changing to generic units but it made no difference. After my current rendering
finishes I’ll try to adjust the zoom limit, if possible…
thank you,
JR
well, so far I found no way to “adjust” this zoom limit.
oh well, not a big deal…
thanks for the suggestions everyone!
actually if you have something small just select it then click zoom extends to selected and then your zoom limits alter to accomodate that
Thank you Da_elf, I do use that method, but sometimes i wish I didn’t need the extra step of selecting something in order to zoom around. It seems funny that a program as capable of many complicated functions has such limited/cumbersome viewport navigation, although it still spanks AutoCAD in that regards 8)
User view FTW :smile:
Is that For The World?
hahaha no, For The Win
Ooooh, thanks!
Have you found your solution?
Well, in a way…Thanks for all the great tips! For now, I just select something and zoom to it, or use user view…using user view is new to me, so I guess that is the solution :slight_smile:
