Zorro - Tool to make section cuts you can render
Have a look over at Sketchucation for a very interesting tool, Zorro. It allows you to cut up your model for a section cut you can render.
Login to see images and download plugin.
Re: Zorro - Tool to make section cuts you can render
Works Great so far! I have always had to go into each component/group and cut my own plane to get rendered sections. This will save some time. Thanks!
Hey,
I tried this plugin out and it works really well, the only thing I found is that once you apply your section cut you can’t undo it and the part of your dwg. you cut is gone, Is there a way to undo the section cut? ???
I made that mistake too, luckly I didnt hit save. So now when I use it, I just do a Save As, then cut the section. Kind of a pain though if you make changes to your model(s).
