Chaos Cloud GPU - Is it forest pro compatible?
  • Chaos Cloud GPU - Is it forest pro compatible?
    As the title mentions.
    Can we use Forest with Chaos Cloud GPU?
    The supported features doenst mention what is and what isnt supported on GPU?
    https://docs.chaosgroup.com/display/...orted+Features
    I ahve a job that im willing to try rendering on chaos cloud again, after some bad experiences
    (frames on a 3970x CPU are 4hrs and frames on a single 3090 are 22m....)
    I guess thats a no?
    Is there an issue with support here? I mean come on lol you want people to use this and then cant bother to provide up to date specs and documentation? How hard can it be?
    What am I going to do? Buy credits and then test it and have to gop through the process of getting a redfund?
    Once more - is forest instancing supported on chaos cloud GPU? the above link mentions only CPU so just wanted to check.
    Thanks
      It should be supported on the cloud, except Forest Color's Tint "As texture on surface" which is coming very soon. If you have any doubts, I can test it for you before you submit it, just send me the scene.
      Peter Matanov
      Chaos
        ok thanks for that
        will give it a go
        i also just got this....perhaps explains the terrible support on chaos cloud?
        Dear Customer,
        due to a technical issue, some inquiries reported by the chaos Cloud contact-form were not logged properly into the support-system. If you are still waiting for our assistance, please respond to this message and we will get back to you as soon as we can.
        We apologies for any inconvenience that this might cause you.
        Regards
        Chaos Support Team
          Yes, there was an issue with the ticketing system and the support guys didn't get some messages.
          Other than that V-Ray 5.1.1 + FP7 should give you what you need.
          Peter Matanov
          Chaos
            I am still having issues with this on Vray GPU
            last time it took over 10 days for a reply
            Forest pack sometimes doesnt render objects - I sent a report but wanted to post it here again, can I ask that you please reply this time.
            Its not running out of vram from a look at the log - i really dont get it
            have also emailed you peter - i cant see an easy way to copy job number from cloud either
              I tried this on a few different scenes and also tried on vray CPU (much slower) but it also drops out some objects consistently
              Is someone able to assist here?
                looks like it only works when you instantattiate the forest pack and bake it to instances
                this is a bug IMO and has taken me submitting 5 jobs to test
                its not ideal to have to bake to instances everytime you render - this is an ongoing issue since I started this thread with ZERO responses to this specific issue
                again im really unimpressed with the support here
                matanov
                  Hi Nic,
                  First of all - you knew that there was a technical issue with the ticketing system back then. So I really don't understand why the attacking comments here.
                  Second, for a user with your experience I'm again confused why there are no scenes attached?
                  Peter Matanov
                  Chaos
