Output Format: JPG - Quality?
  • Output Format: JPG - Quality?
    Hello,
    is it possible to set the JPG quality of the final image somewhere and if not - it seems that the quality is set like 60% wich is kind of low and should be at least 80%
    thx for the help
    Hello,
    It depends on your setup. Can you please let us know what is the 3D host app and the V-Ray version that you are using.
    Also what is the output format that you have set in your 3D host app? There is a difference if you have set JPG as your main output format or if you have set another ( it that case Chaos Cloud will produce JPG as secondary output with preview quality )
      Hello, sorry for the late reply - i have to turn on email notifications
      i use 3dsmax 2021 and the latest vray version for it.
      so the settings from my main output are used for the output format in the cloud render? if i set it to jpg 100% quality this settings should be taken - i will test if this is the case...
