How does chaos cloud works?
  • How does chaos cloud works?
    I never used Chaos Cloud or similar products before so I'd like to know if I need to prepare folders containing the assets such as textures? I've watched the Chaos Cloud videos on how to submit animation and haven't seen anything about preparing the assets folder.
    Just press the render button and it will collect everything for you, simples!
      Does It require continued connection to the I-net? Or does it know to collect all assets and information it needs?
        Vray will create a vrscene file which it uploads to the cloud, once uploaded and rendering starts you can turn off internet. Then connect again to down load the zip file containing all your files. If doinf an animation I would break it up into say 25-50 frames at a time to keep the file size down and download time as short as possible, as things do go wrong in your scene file which you may not have noticed and you can stop it if you need to.
          Thank you for the explanation and tips.
            Hi KushKush,
            For more detailed information about the Chaos Cloud service, you can check our online help documentation.
            Viktoria Dimitrova | chaos.com
            Team Lead, Cosmos Asset Creation
