Chaos Cloud Instead-Of or With Vray Client?
  • Chaos Cloud Instead-Of or With Vray Client?
    I was excited to see chaos had a cloud rendering service but now I'm not sure it's what I thought it was. Is it meant to be used in conjunction WITH a vray client (sketchup extension in our case), just to offload the Rendering functions from the client machine? Or is it used INSTEAD of there regular vray client? I was thrilled at the pay-as-you-go licensing since we only use it occasionally, but if we're buying a full-on license anyway, we may just stick with local rendering.
    Thanks,
    Jeff
    Chaos Cloud manages the rendering remotely, completely offloading the rendering task from your local machine. But in order to produce the scene you will submit to the cloud an active V-Ray license is required for scene setup and preparations on your local machine.
    Ivaylo Marinov
    QA Engineer Chaos Cloud
    Chaos Group
