So is this a deal breaker?
What is "the preview buffer" - do you mean the VFB 2? So does that mean we can;t render jobs using the Vray raw image file option that you want us to do normally?
Could someone please explain what exactly is happening and what steps to take?
Also, can you please make the help files clearer.
People dont use the term "preview buffer" - they say the "vray frame buffer"
The help files says:
So does this mean the render wont work, or the previewing wont work?
Because right now all my renders are failing and I don't know if it's because of an exiting problem, or because of that.
The help file really isn't very clear.
For 3ds Max versions above 2018, when you export and render with V-Ray Frame Buffer 2 enabled, the scene analyzer prints the following warning: "Vrscenes rendered with V-Ray 5 Standalone will only output files without a preview buffer".
When you click on the Preview button in the Cloud submitter, the same message is printed, along with a pop up: "Interactive preview is not supported yet, please wait until the end of rendering". Then an auto-saved preview file opens automatically when the rendering is finished.
