Picture settings Sketchup to Vray Cloud
  • Picture settings Sketchup to Vray Cloud
    If i use exposure settings and curves in Sketchup Vray and would like to render via Cloud i have some troubles with settings.
    Sometimes it takes the values and sometimes not. I have to say that i work only with existing models from preview versions of vray, maybe this is the problem.
    Are there some rules or settings i oversee?
    Hi @miki66,
    If there is a Denoiser or Lens Effect present, there will be an effectResult render channel. In this case, the Color Corrections, Lens effects and the Denoise are all saved in the effectResult. Otherwise, the Corrections are applied directly to the RGB channel.
    Viktoria Dimitrova | chaos.com
    Team Lead, Cosmos Asset Creation
