Installation fail on remote profile
  • Installation fail on remote profile
    The installation of the cloud app client fail on a Windows 10 remote profile environment. We think, there is no double backslash on the beginning of the installation path.
    Hi simon_schmidig,
    Thank you for the report. We've logged it for fixing and will follow up with you soon.
    Vladie
    Vladimir Dragoev
    Product Specialist
    Chaos Cloud
      The installer is copying the required files to the %APPDATA% folder and it does not currently support UNC paths, as in your case. The only workaround for the moment is to manually distribute the following two files - the executable ccloud.exe (located in %APPDATA%\Cloud\Client\) and a vcloud.json file which points to it (located in %APPDATA%\vcloud\client\).
      An example vcloud.json looks like this:
      "executable": "C:\\Users\\Ivaylo\\AppData\\Roaming\\Chaos Group\\Cloud\\Client\\ccloud.exe",
      "webProxy": "",
      "webProxyUser": "",
      "webProxyPass": ""
      You have to redact the executable path to wherever it will be located on your system.
      You can get these files by installing the Cloud Client app on a non-remote profile or we can send them to you directly, if you prefer.
      Ivaylo Marinov
      QA Engineer Chaos Cloud
      Chaos Group
