3dsmax VrayBitmap export problem
  • 3dsmax VrayBitmap export problem
    Hello.
    I'm having a warning in multiple Vraybitmaps when exporting to Vraycloud from 3dsMax.
    The warning is always the same: "...will render differently!"
    How should I proceed to fix this issue?
Name:	Captura de pantalla 2021-08-14 173317.jpg
    www.gaell.com
    Hi gagui,
    This is just a warning regarding a limitation on the Blur parameter of VRayBitmap. We decided to add a warning to the Exporter/Chaos Cloud > Analyze function when the Blur or Blur offset is not at the default value, so you should keep in mind that those materials will render differently.
    As a workaround you can bake the Map result by right-clicking on the bitmap node and select Render Map, then reuse that file as a texture. Other than that, if you don't mind the difference, those warnings should not worry you at all.
    Nikoleta Garkova | chaos.com
      I still get this warning regarding the blur settings. Is it still the case that Chaos cloud doesn't correctly interpret vray's own bitmap nodes? It strikes me as odd that we need a workaround using software from the same company?
      Kind Regards,
      Nathan.
