Rendering with OCIO
  • Rendering with OCIO
    So rendering is complete client loves it and now I need to render in the cloud.
    opps sorry we dont support ocio,
    So is the solution to render out in the cloud sRGB as vrimage then download and re apply oicio in VFB?
    Yes, currently OCIO will not work correctly in Chaos Cloud. We are working on adding support for it and it should be available soon, but for the moment you have to apply it manually from the VFB.
    Ivaylo Marinov
    QA Engineer Chaos Cloud
    Chaos Group
      Thanks for the update, but I cant get the same result rendering in the cloud as RGB then applying the OCIO in the VFB.
      We have 8K renders to get out and no way of doing on our 1 PC, but we have to apply the OCIO colour correction as this has now been approved by client.
      So can you tell what setting I should send to the cloud, then once downloaded we get the predicted result when OCIO is applied.
      Thanks for your help
