Hires render failed
  • Hires render failed
    Hi, I have issues rendering a hi res 16565x18898 image. I have done a test render 1600x1800 on my machine and the cloud and it renders fine. I believe I am still within the Chaos limit of 400mp and I have plenty of credits.
    The render gets stuck at roughly 5% and then fails. Also I would appreciate being pointed in the direction of documentation for tile rendering with Vray in Houdini as a possible workaround.
    Many thanks
    Hi simon_ryder,
    Can you share a job ID of the job that has failed for you on Chaos Cloud?
    Rendering high-resolution images, it will be recommended to use Bucket type for the Image Sampler and Brute force + Brute force for GI. If you are using a different render setup, you can try this one to see how it goes.
    Viktoria Dimitrova | chaos.com
    Team Lead, Cosmos Asset Creation
      Hi viktoria.dimitrova
      Thanks for getting back to me.
      The job ID is Andy 14000_vray
      Thanks for the suggestions I'll give them a go.
