Export Problem "multiple simultaneous render output not supported"
  • Export Problem "multiple simultaneous render output not supported"
    Hello,
    I wanted to export a scene, what does it mean?
    Thanks Click image for larger version
Name:	ChaosCloud scene.png
    It had todo with the separate render folders from Vray Raw saving.
    I disabled that and it worked then as multiChannel EXR.
      Hi Alexx31,
      Currently, you can only export one output from 3ds Max, and it should be either a RAW image file or as separate render elements. We have this logged in our internal bug tracking system as ID: VMAX-11840.
      Viktoria Dimitrova | chaos.com
      Team Lead, Cosmos Asset Creation
        I have the preset "Vray Raw Image files" and I got as expected a multichannel EXR which I could perfectly read out in AfterEffects – but just as mentioned the beauty pass was corrupted with denoising.
