Bloom / Glare Effects
  • Bloom / Glare Effects
    Good Morning
    In normal rendering, you can add Light Mix, and then perform all kinds of operations such as Bloom, Glare and the like.
    In cloud rendering, in addition to the rendering itself, I also received an EXR file, and I understand that it is intended for making changes in Photoshop.
    What about doing the above - Blomm / Glare? How can this be done after rendering with cloud?
    Thanks in advance
    Ittai Frumkin
    Dear ittai_frumkin, hello.
    The desired from you could be easily done - add Lens Effects after rendering with Chaos Cloud.
    Before submitting to Chaos Cloud please go to Settings > Render Output > Save Image and enable it.
    Choose some location on you PC and as file type choose vrimg.
    You will see that besides jpg, you will receive also vrimg as an output format, like this.
    When you download the archive with the final render from Cloud, it will contain these type of files.
    And vrimg could be loaded in the V-Ray Frame Buffer inside the host platform directly (from here), where you could enable Lens effects and save the image as usual with the Save button.
    So, enjoy them both - Cloud & Lens Effects.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      Thank you
      you helped me alot !
        Glad to help!
