Chaos cloud "turn off interactive rendering" problem
  • Chaos cloud "turn off interactive rendering" problem
    I am having a problem with chaos cloud saying that i need to turn off interactive rendering because interactive rendering is not supported on chaos cloud.
    Honestly i dont know how to turn it off because i use the icons to select and start rendering interactive or normal (if i am correct in vray 5 or 4 there was selection for interactive under the cpu/gpu/rtx selection but now its progressive selection which doesnt help)
    I have searched everywhere and cant find anything on this topic.
    I am using Vray 6 with Sketchup 2022
    Thanks!
    Hello erik_kovaek
    Thank you for your inquiry. Since you have sent us a ticket already, let's investigate the issue there and I will make sure to add the solution to this forum post as well, once we have a conclusion.
    Thank you in advance!
    Zahari Ivanov | chaos.com
      Just posting the resolution from the ticket for everyone's sake who is reading.
      We presumed that this project might contain some "corrupted" data in its render settings. Which is why we recommended the render settings to be reverted to their default values. And this helped.
      Thanks,
      Vladie
      Vladimir Dragoev
      Product Specialist
      Chaos Cloud
