I am ready to send a job to the cloud, but I have had issues with rail clone materials. The material isn't a rail clone material, but the material I have isn't rendering correct on the V-Ray Cloud. Here is a screen grab of the material. When it renders, there isn't any randomness like you see in the screen grab.
Railclone
Railclone
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
This is from my GPU render, which is the same thing I get from the cloud render, although I use CPU in the cloud.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Hello! Unfortunately there's a known bug where "Use Instancing Engine" is not supported when submitting to Chaos Cloud. You could disable it and it should render fine:
Assuming you are not depending on it, that is.
Other than that the problem is logged and would be hopefully fixed at some point.
- Likes 1
PERFECT! Thank you!Bobby Parker
phone: 2188206812
- Windows 11 Pro
