Stop EXR Output
  • Stop EXR Output
    Is there a way to prevent the EXR output? I tend not to use it and it is a sizable file to download. I'm using vray fro SKP.
    Thanks!
    Hi jacksivyer,
    Yes, you can select different output file type for your images. This is done in the Settings tab of the V-Ray Asset Editor. You have to expand the Save Image options and select the needed output file type as seen on the screenshot. Chaos Cloud will respect you choice when you submit the scene for rendering. Please let me know if this doesn't work for you.
    Vladimir Dragoev
    Product Specialist
    Chaos Cloud
      vladieYes, that worked for me, many thanks.
      It was not so obvious to me!
        Hey jacksivyer,
        You can read more about it in the Chaos Cloud documentation.
        Bests,
        Vladie
        Vladimir Dragoev
        Product Specialist
        Chaos Cloud
