File naming
  • File naming
    Hello,
    Would it be possible to have the same file naming as rendering locally in 3ds Max?
    At the moment as an example whilst rendering locally for the RGB there is origRGB.0000 and RGB_color.0000.
    However on the cloud there is .000 and effectsResult.000.
    Not only are the names different, but there’s a difference of 3 and 4 leading zeros.
    This becomes an issue if we render some frames locally and some frames on the cloud. Different file naming means that compositing programs like AE don’t recognise all the frames as one sequence. So we have to manually rename sometimes hundreds if not thousands of files so they all match.
    Thanks,
    Hi James,
    We are currently working on making the default frames number padding 4 symbols when the job is submitted from 3ds Max. I'll keep you updated about this.
    As for the name of the render element, I'll talk with the V-Ray for 3ds Max team as we have to sync how the names are exported. Expect a follow-up from me next week.
    Bests,
    Vladie
    Vladimir Dragoev
    Product Specialist
    Chaos Cloud
      it would be nice to be able to activate and deactivate the different tokens.
