Interior WIP - Hospital
  • Interior WIP - Hospital
    Hi to all,
    Just a work i did . I'll put my hand again on it.. but now i have lot of works. C&C are as usual interesting for me.
    Image 01
    Image 02
    Image 03
    Rpc.. were only for test .. i'm looking for another solution (any idea?)
    Thanks
    Marco
    Workstation Core i7 6900 - 32GB RAM - GeF970
    Dual Xeon E5-2630 - 32GB RAM
    NICE ARCH VIZ... really, LIKE THE LIGHTING...
    but DAMN those RPC-s... on all images they fly an inch above the groung...
    THEY SPOIL the beatiful vizs....
    on IMAGE 3, the door on right - looks wierd...
    .:: FREE Your MINDs, LIVE Your IDEAS ::.
      good results...
      I think the rpc are flying because of the cameracorrection modifier...
      there is a problem with it.
      best regards
      themaxxer
      Pixelschmiede GmbH
      www.pixelschmiede.ch
        nice renders. there's quite a lot of blotchy noise going on around the doorframes and skirting though...what are your GI settings?
        i'd suggest chamfering a few of the sharp edges on the door / window frames etc. to add a bit more realism.
        if you're going to use RPC's in stills, it's usually best to comp them in photoshop afterwards - that way you get better control over colour balance / white edges / floating problems.
        when the going gets weird, the weird turn pro - hunter s. thompson
          Thanks
          Thanks
          Yes Maxxer... i think u're right about camera correction... i will take a look on it, maybe could be the reason.
          About the Door , u're right.... i want to improve that corner .
          Btw.. i'm looking for a better solution than RPC... Low Poly? .. Post Production?... just Grey translucent shapes? ... actually don't know which one could be the best solution.
          Best Regards,
          Marco
            i don't think there is a 'best solution' when it comes to people in visuals - each one has it's own merits and problems.
            if you do find the perfect solution though, pleas feel free to share!
              Ehe...
              I will...
