I've got something odd happening with white materials using progressive path tracing. There are four boxes with gray, red, light gray and white Vray materials applied. The ground plane is also white. The white box in the foreground appears like it's self-illumniated when using PPT. There are no shadow details. Even if I lower the sky value from 255 to 128 or 50 there are still no shadow details. There are no lights in the scene - default lights are disabled. Only using skylight for illumination. Is this the way it's supposed to work?
Scene file (Max 7.1)
Wireframe
![](http://home.comcast.net/~michaelgregg/ppt_wire.jpg)
Rendered with irradience map / QMC
![](http://home.comcast.net/~michaelgregg/ppt_irqmc.jpg)
Rendered with Light cache / progressive path trace / sky = 255
![](http://home.comcast.net/~michaelgregg/ppt_sky255.jpg)
Rendered with Light cache / progressive path trace / sky = 128
![](http://home.comcast.net/~michaelgregg/ppt_sky128.jpg)
Rendered with Light cache / progressive path trace / sky = 50
Wireframe
![](http://home.comcast.net/~michaelgregg/ppt_sky050.jpg)
