I posted this one while back, but it went through some major changes. I am posted because I tried some new color grading techniques and I would appreciate comments to see if it was successful.
63 Ponds House
63 Ponds House
5 PhotosBobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
- Likes 2
And a couple of interiors
2 PhotosBobby Parker
phone: 2188206812
- Windows 11 Pro
- Likes 1
Both interiors and exteriors rendered in about 30 minutes in 4K using CPU. I wanted to use GPU, but without the support of RAW elements and the lack of reflection on exterior glass, using NEXT, I needed them. Using GPU wasn't any faster on these, anyway.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I did catch that the marble table doesn't have a base after I rendered them out, but they pulled back the camera at the last second and that was when it was revealed.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by rusteberg View Postnice job on the evening shot - glare is a bit much in that view and i also think the pool illumination and fire are too bright - i would light the pool from the other side and make the spheres in the casita invisibleBobby Parker
phone: 2188206812
- Windows 11 Pro
I used an HDRI to light both the exterior and interior.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Nice work as always Bobby !Jez
3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
---- Updated 06/09/23 -------
- Likes 1
I like your work, especially what your are doing with the vegetation.
but I have to be honest, the houses always look kind of flat and too perfect for my taste. I can't put my finger on it and say what it is exactly though...Check out my tutorials, assets, free samples and weekly newsletter:
www.AddYourLight.com
Always looking to learn, become better and serve better.
I usually start with basic materials and I start adding detail if needed. I do add falloff reflection to most everything. Maybe some dirt.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Sure.
Why the falloff though, if I may ask?
Recently I make my materials 100% white in the reflection slot and then control the look through glossiness and bump, so they actually react to light stronger and accurately. Obviously sometimes you have to cheat.
Maybe it is just broader variations of the materials, as we talked about in another thread (imperfections) and more depth and variations of that. Like a varying displacement. Or slight rotations (just 1 degree or so) of elements..
You are building with Railclone, right?
I'll have to give it a try. I use Railclone for some things, but not often.Bobby Parker
phone: 2188206812
- Windows 11 Pro
