hm...
try adaptive subdivion aa -1/2 (default)
lower reflection/refraction max depth in global switches from 5 to 3
change irr preset from "very low" to "low"
you can leave the sample lookup to "overlapping" or change it to the default "density-based"
change the subdivs in the qmc gi from 8 to 16
change the adaptive amount and noise thresh in the qmc sample from 1 to 0.75 and 0.02 respectively. Min samples should be 16 let's say. Also if you want to test quickly how does the image look - change global subdivs mult from 1 to 0.
your material is good imo - you can try to render it with reflection interpolation, change the subdivs from 24 to 60 let's say. And in the reflect interpolation rollout change interp. samples from 20 to 80. This step with the material is not necessary though - you can just test.
You can also leave the material as it is only change the brdf type from blinn to ward.
See how fast does it render with these settings and tell me - if you have problems and you are willing to share the scene - send it to my email.
btw what is your studio setup?
