Latest NPR work
Your centering of the flash file doesn't work properly. In firefox I have to have a 1600px wide window in order to see your entire flash file because of big wide space to the left.
And having the buttons be just the tiny little dot instead of the big icon is annoying
The load window does state that you need to change your desktop resolution to 1280x1024 or higher.
RE: I just tested it (views 3 and 4) on 2 different computers and it worked fine.
Dy: I will be changing the hit area to cover the whole view/scheme areas.
Any comments on the content?
Vray, FinalToon and Photoshop
Vray for the diffuse and GI, Final Toon for the lines, and a series of the below listed PShop plugin to get the desired effect. Also used a gradient mask for the edge of the image.
Get this plugin for PShop:
http://www.trimoon.com/Impressionist.zip
