Living, Dining, Bar and Veranda
  • Living, Dining, Bar and Veranda
    I want to share some renders from a work of a few months ago. I've used Cinema4d, Vray, Marvelous Designer, some small tuning in PS.
    Some statistics, about 50 million polygons plus render instances whenever possible, physical sun/sky, about 300 area lights, some soft boxes when needed, rendered in 4K in about 1-2 hour.
    Mostly modeled by me, I've used a few laser scans for furniture and moulding.
    Texture and shaders have been created by me, many for this specific project, I'll sell many of these shaders in a bundle as soon as Vray 5 for Cinema4D will be released, I'll also try to build them for Vray for Max.
    Hope you'll enjoy and I'm always looking for suggestions for improving my work!
    This is the living area:
    Click image for larger version  Name:	 Views:	0 Size:	1.15 MB ID:	1076770Click image for larger version  Name:	 Views:	0 Size:	1.21 MB ID:	1076769Click image for larger version  Name:	 Views:	0 Size:	1,012.9 KB ID:	1076768Click image for larger version  Name:	 Views:	0 Size:	1.27 MB ID:	1076767 Hi everybody
    3D Scenes, Shaders and Courses for V-ray and Corona
    Dining:
Name:
ID:	1076774Click image for larger version
Name:
ID:	1076773Click image for larger version
Name:
      Bar:
Name:
ID:	1076776Click image for larger version
Name:
ID:	1076777Click image for larger version
Name:
        Veranda:
Name:
ID:	1076780Click image for larger version
Name:
          Some details:
Name:
ID:	1076783Click image for larger version
Name:
ID:	1076784Click image for larger version
Name:
ID:	1076785Click image for larger version
Name:
ID:	1076786Click image for larger version
Name:
            Where are the cherubs?
              These really lack detail don't they?
                Wow! That looks like an amazing amount of detail. Thanks for sharing!
                  Stunning modeling and texture details, impressive indeed.
                  It bothers me a bit the obvious IRMap.
                  Would you be so kind as to render one version with BF as primary GI engine, and share it? :P
                  Lele
                  emanuele.lecchi@chaos.com
                  Disclaimer:
                    No cherubs, clients from India won’t appreciate
                      Believe it or not this design is quite clean compared to my typical work, other projects are far more complex/detailed
                        Thanks for sharing!
                        Thank you for this amazing software, can’t wait to use Vray 5 in production!
                          Hi Lele,
                          everything it’s already done in BF/LC
                          Probably you get the impression that is IM because I had a tight deadline for this job (3weeks/1person) so to save time I ended up using a rather high AA threshold coupled with heavy denoising in a few views, this may lead to splotch-like artifacts in some circumstances. I’ve also used a few softbox that can flatten out some details depending on the incidence of the light, maybe this also gives you the impression of IM.
                            Yes!
                            That's exactly what i was seeing, some splotches around the fine details and corners, and some evenness in flat areas!
                            To be fair, minute stuff visible at higher zooms.
                            To be fairer, it's the fault of the images for drawing the viewer in as they try and see more of the awesome detail.
                            Keep it up, this stuff is seriously impressive!
                            Lele
                            Disclaimer:
                              Thanks a lot Lele
