We have done visualisations of cruiser boat for advertising purposes for client from Germany. Our work included boat modeling, scene rendering and post-production.
Cruiser boat
Nice job! Our lakes are frozen over, so it is nice to see .Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
I'm afraid that I must be a little more constructively critical if you don't mind
I think that the background treeline needs some love, as it is very sharp and where it meets the sky is jagged - maybe you could blur this to add depth of field/atmospheric haze.
The main foreground trees have the usual white halo coming from an incorrect alpha output.
The rocks appear to be floating, especially in the second image. Some small colour/texture variation in them could look good also. Also the planes on which the grasses are scattered can be clearly seen, in the second image.
There is an odd large bump on the glass which may be better if the panels were separate and the bump a little less.
There is a pink box inside, which looks maybe a little odd.
Depth of field would add immeasurably to the whole image. Unfortunately the window glass is blurry but nothing else is, which looks a little strange.
I would argue that the composition needs a little balance - with the first image needing more space at the bottom, so a bit more water - and maybe something coming into frame on the left....a tree perhaps.
Similarly with the second image - you could move your trees a little so they don't overlap, shift the boat to the left a bit and have a foreground brand come in from the right
All of these are pretty quick fixes, so will look forward to an update
