Cosmos test
  • Cosmos test
    Here is my Cosmos (and ACES) tests. Images straight from VFB (converted to sRGB in Photoshop).
    Models from Cosmos library without any changes. Lighting from Cosmos HDRI.
    I like Cosmos
    This is another one I love! This feel of presence you have! No idea how you do that lol...also what is Cosmos?
    www.hrvojedesign.com
      Cosmos is Chaos Group assets library for use with V-Rray:
      https://www.chaosgroup.com/cosmos
        The lighting atmosphere is great. Bravo !
        How did you light your stage? Only with an HDRI?
        Can you share your settings or your scene to study it?
        Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
        Sketchup PRO 25.0.634 + V-Ray 7.10
        3DS Max 2025.3 + V-Ray 7.00.08
        3DS Max 2026 + V-Ray 7.00.08
        Chaos Vantage 2.8
        GeForce Studio Ready Driver Version 572.16​
          These are amazing. Would love to know how you were able to work with ACES in Photoshop. I've only had luck in After Effects. Unable to figure out the workflow in Photoshop yet.
            I have wide gamut monitor (NEC) which I can set to work in DCI mode (proper ICC profile is set at OS level so Photoshop "knows" about monitor).
            This is my settings in VFB:
Name:	ACES settings.jpg
            After saving 16-bit png and opening in photoshop I assign to image DCID60.icc profile which I found on internet. And I make levels adjustment layer whith this settings:
Name:	photoshop settings.jpg
            And I see image pretty the same as in VFB.
            I don't know if this is "correct" workflow
