Error creating bitmap ???
  • Error creating bitmap ???
    Can it be right that there is a limit of how hi you can render your image in V-ray , or have I done somthing wrong
    Go to Customize»Preference»Rendering and turn on Bitmap Pager
    You should have posted this in the general section.
      the best solution for this problem is to render to regions,
      then you can render as large as you need to.
      go to the support page for directions, it has an example you can follow. so go to the 3dsmax website and then to the support page, then type in error creating bitmap and it will have a example for you. hope this helps
      Jet
      Pain is Weakness Leaving the Body
        So no one gets lost http://new.chaosgroup.com/forum/phpB...06c51c82b5f026
        Eric Boer
        Dev
