Modern bedroom Visualization, Vray GPU
  • Modern bedroom Visualization, Vray GPU
    Hello,
    I reworked shading and lighting for this scene using Vray GPU and ACES 1.2
    Rendered on 2x 3090s, around 20 minutes in 5k resolution
    No post processing, only Vray Lens effects in the frame buffer
    High Resolution here, https://i.imgur.com/rkdSuXa.jpg
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    Great piece of work. Can you post the orignal non-aces version to compare?
    Thanks for that shaderball/links to aces by the way.
      very realistic rendering, great job!
      Jackie Teh
      3ds Max 2023, V-Ray 7 Update 1 [7.10.00 build 00000]
      AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
      Website: https://www.sporadicstudio.com
      Email: info@sporadicstudio.com
      YouTube: https://www.youtube.com/c/SporadicStudio
        Original scene here, (Vray Next)
        Click image for larger version  Name:	imgpsh_fullsize_anim.jpg Views:	0 Size:	1.44 MB ID:	1121670
        And ACES version below, (Reworked the fabrics using Sheen, UVW randomizer on paint, ACES, Multisub texture for variation on leaves, wood, metals on the wall..etc)
        This more about Vray Next vs Vray 5, I could have spent some considerable time in Vray/Photoshop to fix the first render.. and the old hacks of using falloff maps in diffuse to fake the sheen effect, the workflow is just better and faster in Vray 5
        About ACES, I think everyone should adapt to that in Vray.. Tone Mapping and wide gamut rendering are very powerful, and the workflow is very easy in Vray it takes couple of clicks to convert scenes.
        Thanks for the kind words
        Muhammed Hamed
        chaos.com
          Night and day difference for sure.
          I took one look at that shaderball scene and needed no convincing
          The hardest part was trying to figure out where to actually get the files from Github....they should make it a little easier
            Hi Muhammed Hamed
            I Have seen your work in vray gpu and vray maya and looks really amazing!!!
            The bedroom render looks very impresive, very realistic, i use vray for sketchup and render with vray gpu, i use 2 2080 ti with nvlink.
            Thank You very much for taking your time showing a comparison with srgb and aces, and aces looks amazing, it has more light bounces, more color bleeding, lights look better, and the colors... Oh man!!! Amazing colors with aces... In vray for sketchup we don't have this option and i already talked with Konstantin that this is something important, i hope in the future we can have this option for vray for sketchup and Also Muhammed Hamed may i ask how things are going with vray light cache in gpu, i AM almost crazy to use this option!!!, i have a i7 8700k and it is not that powerful, light cache with cpu is very slow but with this new option things are going to change... For vray for sketchup, i hope we can have this option soon!!!
            Thanks Muhammed Hamed ( My English is not very good, sorry)
              Hello Luis!
              You English is great, don't worry about that and thanks for the kind words
              Originally posted by luisgamino2 View Post
              Hi Muhammed Hamed
              I'm using the latest stable build for Max/Maya, Light Cache works nicely for me. It is a big upgrade to the GPU IPR in my view, IPR is now super fast
              I use 1000 subdivs for IPR and 3k for final rendering on this interior. I spent hours working on the scene in IPR without a single crash
              And yes, it is much faster than CPU Light Cache
              I'm not sure which version Vray for Sketch uses, the recent stable builds have good GPU LC .. fewer issues than before, you can give that a try
              And about ACES, I have been using this workflow for 2 years now and I'm super happy with it. Once you adapt, you will never look back and I learned a lot of things throughout this journey. Hopefully you guys get it soon in Vray Sketchup
              Best,
              Muhammed
              Muhammed Hamed
              chaos.com
                awesome renders
                e: info@adriandenne.com
                w: www.adriandenne.com
                  Maybe I have my ACES setup wrong....but its the defaults shipped with Maya 2022 and Vray 5....but my renders always look super saturated compared to sRGB. Is this to be expected? Most, if not all of my work is making cg cars drop into photo backplates. I just dont find the ACES matches the plates using the default maya 2022 + vray 5 settings. I havnt looked into it at all tbh, and Ive just had to tweak some things to make it look and work like Maya did in 2020.
                  Website
                  https://mangobeard.com/
                  Behance
                  https://www.behance.net/seandunderdale
                    Hello!
                    It is recommended to use ACES through OCIO in Maya 2022(like older versions of Maya), even though it ships with an ACES setup. This is what I do at least, as I use OCIO in Nuke and many other apps so everything uses the same OCIO config and the images would match
                    My first guess is that this has to do with the IDTs you use, wrong ones tend to make colors more saturated. If you can share a scene or some screenshots of a render ACES vs sRGB, I will be able to help you
                    Converting a scene to ACES doesn't make it more saturated, no
                    Backplate needs to have an IDT of "Output sRGB" ,so the ACES tonemapping doesn't affect it. This is probably what most people struggle with on ACES, having a Logo to match or a backplate
                    If you have a simple scene I will show you a correct setup. Take a look here for more info,
                    https://forums.chaosgroup.com/forum/...-aces-workflow
                    Best,
                    Muhammed
                    Muhammed Hamed
                    chaos.com
                      Hi Muhammed
                      I have a question since the release of vray 5 for sketchup, in the new VFB appers a new option tone mapping We don't have color management as vray for 3d max and maya... So in the new tone mapping appears new option... aces cg... But should i use these option??? we don't have color
                      Management in vray for sketchup... So what kind of benefits can we have when we choose aces Cg instead of linear srgb...??? Also in the tone mapping option there is an option called log space... When should i tick or untick that option, only when i use aces??? i don't want to have textures in ACES and lights in srgb... It is going to look incorrect.
                      I think sometines chaosgroup team needs to explain that... Because this is diferent from sketchup, rhyno, maya, max and Houdini...
                      Thanks Muhammed for taking your time explaining vray gpu light cache, i think the same it is going to be a great update for ipr and production render in vray gpu render
                      and thanks in advance for this tone mapping aces questions!!!
                      ​​​​​cheers!!!
                        Hello Luisgamino
                        You don't need to use ACEScg as tone mapping space, in the filmic layer. You should keep it on Linear sRGB, it will get the job done (because you are rendering in linear sRGB)
                        This option basically tells Vray which RGB primaries the EXR is using on how the filmic layer will work. Using ACEScg at this step doesn't add much, it is best to adapt to the entire ACES workflow byhaving ACEScg as your rendering space.
                        Not much honestly, ACES is not just about this tone mapping step. ACES goes beyond that, you need to have your textures, lights, kelvin temperature..etc in ACEScg to adapt to this workflow fully. Vray takes care of that in Max/Maya , fingers crossed you can wait for that to be brought in Sketchup
                        I don't use that option myself, most likely you will not use it either
                        "A log profile, or logarithmic profile, is a shooting profile, or gamma curve, found on some digital video cameras that gives a wide dynamic and tonal range, allowing more latitude to apply colour and style choices. The resulting image appears washed out, requiring color grading in post-production, but retains shadow and highlight detail that would otherwise be lost if a regular linear profile had been used that clipped shadow and highlight detail. The feature is mostly used in filmmaking and videography."
                        Log space has its uses in some workflows, but here is a video on using Filmic with ACEScg to control highlight compression .. This is how I use ACES in Vray 5
                        https://www.youtube.com/watch?v=1mcE5cJ198U
                        Let me know if you have more questions,
                        Best,
                        Muhammed
                        Muhammed Hamed
                        chaos.com
                          yes, very very nice! super real looking..
                            Hi Muhammed
                            Finally i understood how does it work, thanks again for taking your time explaining aces and the tone mapping in the vray frame buffer, until we dont have the color management as maya and max it would be useless aces cg in sketchup, but as you said fingers croosed that we can have hopefully this amazing feature.
                            Best regards.
                            • #15
                              Hi Luis,
                              The conversions are part of Vray's 5 core, it is probably just about having the UI for the ACES control in Vray Sketchup. It shouldn't be hard to implement, hopefully they add that soon
                              On the other hand you can still work in ACECcg in Vray Next(or anything that doesn't support OCIO natively), the workflow is much harder involving manual convertion of your textures externally and not using Vray sky or color temperature
                              It is probably best to wait, the old manual workflow for ACES was not great. It is much much easier/better in Vray 5
                              Best,
                              Muhammed
                              Muhammed Hamed
                              chaos.com
