vray and fog, smoke and fire creation
  • vray and fog, smoke and fire creation
    Hello. I work on c4d and I would like to create nice fogs and clouds in my work. I did not find any good tutorials. I only found plugins like realflow and turbulenceFD. But I don't know how to combine them with a stage where there are vray materials, vray lights. How to combine it? Please give me some tips. I am a beginner in this topic, so I am asking for simple descriptions. Thanks
    Hello pendzik
    Environment fog and Areal Perspective can do a lot in Vray, it is what I use in most cases. Do you have a reference for what you are trying to achieve?
    Here is a good example of volumetrics,
    https://www.behance.net/gallery/5365...GT2-on-VRScans
    Andre made a video about his workflow here,
    https://vimeo.com/257297747
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Hello. Thanks for answer. I uses aerial perspective and environment fog. I want to get irregularities in the fog, such fog streaks in the frame. Do you know how to make things like this with vray? like creating cigarette smoke or steaming coffee from a cup? I have a problem with how to create and render such things with vray. Or how to combine rendering with vray of work effects in e.g. realflow or turbulence. Thank you for your attention
        Vray's Volume Grid supports .vdb files that Realflow uses, it will be part of how your approach this. I can give this a try with Houdini, then render in Vray C4D and get you a file
        I don't have access to Realflow or Turbulance at the moment
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          On another note you used the wrong forum section, posting in the C4D section will get you more answers from the C4D users
          Muhammed Hamed
          chaos.com
            Muhhamed, thank you so much again for paying attention to me. You are just slowly explaining to me my problem which was not knowing how to connect plugins like realflow and vray. you wrote about vraygridvolume and vdb files. How it's working? Do you have any tutorials to show? Does it rely on importing a vdb file into vray? I am a very beginner in combining techniques. Have a nice day. Again thank you very much.
            best regards
            rafaƂ
              Hey pendzik
              Here is a C4D file with a good Volume grid smoke example,
              https://drive.google.com/file/d/12Ax...ew?usp=sharing
              This is a very good tutorial on Volume Grid in Vray, it is going to be helpful
              https://www.youtube.com/watch?v=04abld5m1cc
              You go to input tab and load a supported format, .VDB .AUR .F3D
              Then you use these parameters to control smoke, have a play with these. I used the GPU RTX engine for my scene but the IPR doesn't update sadly you will need to restart the render every time
              If you have more questions let me know, have a lovely day as well
              Best,
              Muhammed
              Muhammed Hamed
              chaos.com
