Yet another Pool Villa
  • Yet another Pool Villa
    Yet another pool villa, quite a bit bigger compared to the last one I've posted here in the gallery
    Some statistics: 15million polygons + render/multi instances + Vray Proxy. 2D displacement for the cobblestone. Physical sun for both day and night sky, plus area and sphere light for the night views. Everything modeled by me in Cinema4D except for the palm trees, cars (from Cosmos library) and a couple moldings. About 10 days of work, it was a tight deadline so there was no time to play with pool caustics. Render time for 4K images between 30 and 60 minutes on a single 8core system, small tuning using Cryptomatte and minor editing in PS.
    I'm not very satisfied with the night shot so feel free to suggest about how to improve the illumination and the mood
Name:	vista piscina1r.jpg
ID:	1151540Click image for larger version
Name:	vista piscina2r.jpg
ID:	1151537Click image for larger version
Name:	vista piscina3r.jpg
ID:	1151535Click image for larger version
Name:	vista ingresso2r.jpg
ID:	1151536Click image for larger version
Name:	vista ingresso1r.jpg
ID:	1151538Click image for larger version
Name:	vista ingresso4r.jpg
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
    Some wireframe:
Name:	Schermata 2022-05-31 alle 23.43.46.jpg
ID:	1151543Click image for larger version
Name:	Schermata 2022-05-31 alle 23.38.36.jpg
ID:	1151544Click image for larger version
Name:	Schermata 2022-05-31 alle 23.45.46.jpg
ID:	1151545Click image for larger version
Name:	Schermata 2022-05-31 alle 23.42.58 copia.jpg
      A ton of detail. It is interesting that you model your tire tracks; it works well.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        just superb….
          It is a very quick and flexible setup, draw a spline, sweep, done. The sweep already have UV coordinates so you just need to add a simple shader, in this scene you can see it better:
          Click image for larger version  Name:	1410x800-view20.png Views:	0 Size:	1.23 MB ID:	1152007
          This works well for every other floor/asfalt details, like crosswalk, dirt, etc, it is also very quick to render.
            Nice, just tried this with Maya sweep mesh and it works the same. Did you use Sun / Sky for the background sky render?
            Website
            https://mangobeard.com/
            Behance
            https://www.behance.net/seandunderdale
              Yes this technique will work in every engine, for the tire tracks I also add some gradients to blend the start and the finish of the track with the floor otherwise you will get a sharp transition.
              The scene is illuminated with a physical sun/sky but I've added a background picture applied on a large cylinder to get some clouds (I'm on C4D and we do not have Vray6 clouds system yet).
