WIP - exterior entry - stone "blurry" reflection p
  • WIP - exterior entry - stone "blurry" reflection p
    Here is an entry way to a hospital I am currently working on. I am having problems with the stone material. I would like "blurry" reflections but am having difficulty, obviously. Can someone give me some tips on how to get a blurry reflection in the stone material. I don't want it to look like a skating rink but alternatively I don't want it to look
    flat and dusty. Thanks in advance for any tips.
    Regards Peter.
    P.S. - thanks to Candelero for the tip from the general about geocities for posting images.
    despite Candelero's tip I just see a red x...
    Regards, Michael
    This signature is only a temporary solution
      really - it showed fine in the preview and after a new login as well??
        I can see them fine.
        Chris
        The Revitlution
          I think it is because of geocities being so big that sometimes it may be down or slow and just doesn't load fast enough.
          Peter
            Use the reflection settings you have in image one, but change the glossy value to about .8 - .85 instead of 1.0
              Thanks Dynedain - I'll give that a try.
              Regards Peter.
                im assuming that the textures are not final, but you should really change the standard max "cedfence" material from the ceiling of that walkway overpass.
