Vantage Tests
  • #16
    couple more
ID:	1200133 Click image for larger version
    • #17
      here's some more... struggling a bit with the hair density when applied in vantage. per face and per area doesn't appear to change the density... at least in this case it didn't.​
      Please check the Vantage log for warnings.
      There is (by default) a limit of 50 million segments per hair object.
      We added this, so you don't run out of GPU memory by mistakenly entering values that are too large.
      If you are working from a vrscene, you can select the VRayFur object from the Vantage object tab and raise this limit.
      Greetings,
      Vladimir Nedev
      • #18
        Whoa.... that did some stuff. The really fuzzy one pulled just under 20gb at 4k render. That makes sense. Thanks for explaining that Vladimir!
ID:	1200154 Click image for larger version
ID:	1200157 Click image for larger version
ID:	1200155 Click image for larger version
        • #19
          Is there a way to preserve model rotation & scale for scattered objects in vantage? Similar to scatter options in Max?
          I need to fill that firepit with gravel the same way it populates the edges of the pool deck.
          I could just do it in max and port it over to vantage, but then it's going to come in as a block of nodes. Lots and lots of nodes that can't really be controlled without exporting and importing those objects as individual vrscenes.
Name:	Birdsall Pool-5_VantageTest-2_24-01-24_07-46-56-130.png
ID:	1200589 Click image for larger version
          • #20
            Here's some more test renders... That desert scene lead me down a tyflow rabbit hole the other day that i'm still trying to recover from.
ID:	1200601 Click image for larger version
ID:	1200598 Click image for larger version
ID:	1200602 Click image for larger version
            • #21
              Is there a way to preserve model rotation & scale for scattered objects in vantage? Similar to scatter options in Max?​
              There is no option for this in Vantage, but the behavior should be as if it's ON, i.e. rotation and scale of the model object should be preserved.
              We will have the option in future versions (and for new Scatter objects it will default to OFF like in 3dsMax).
              Nice desert
              Greetings,
              Vladimir Nedev
              • #22
                Thanks Vladimir. Here's some test renders from the pool scene I ran today setup with a different scene state.
ID:	1200632Click image for larger version
                • #23
                  Here's some shots I put together from the pool scene testing out various things:
                  • #24
                    It looks way better animated. Great job
                    • #25
                      Thanks Bart! : )
                      • #26
                        These are all awesome. I am getting very soft renders in Vantage. How are you guys getting such sharp outputs? What is the secret sauce?
                        Bobby Parker
                        www.bobby-parker.com
                        e-mail: info@bobby-parker.com
                        phone: 2188206812
                        My current hardware setup:
                        • Ryzen 9 5900x CPU
                        • 128gb Vengeance RGB Pro RAM
                        • NVIDIA GeForce RTX 4090 X2
                        • ​Windows 11 Pro
                        • #27
                          Have you tried disabling the bloom in Vantage ? It's on by default.
                          Greetings,
                          Vladimir Nedev
                          • #28
                            I have, but that isn't it. I'll do some comparisons when I get a chance.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              Lookup Tables
                              • #30
                                LUT raw footage:
                                It actually loses a lot of color and contrast on compression. Top is vimeo compressed file and below is the raw mp4
                                try playing around with that.....
