I am animating a full site, exterior, for a new hospital. It has a lot of polys. Having said that I am happy with the frame time but the quality is not acceptable. I am using a Med-anim setting -see settings below, if I go to high it will bomb out. I have already enabled 3 gig switch.
I'm wondering if there is something wrong with my settings to achieve a smoother non flickering animation. I am attaching a piece of my animation. The material especially bitmapped objects appear to have th moire effect and flicker quite badly. Even the wood slat fence, which is geometry, is flickering. Please advise - thanks in advance.
I am using Premiere to export the TGA files with no compression. I DivX'd the clip to get it small but the large uncompressed version is similar.
Also if anyone would like to give me a hand with this and other projects please let me know and we can discuss $$ rate and more specifics. I am swamped and need help. Thanks again.
Regards PEter.
HERE IS THE AVI FILE. - DIVX IS REQUIRED.
[/img]http://www.geocities.com/pshupe68/anim-divX.avi
Regards PEter.
