Gnomon Workshop
  • Gnomon Workshop
    Hi so it's been a while since I used Vray, but I started using it again, and made this Gnomon workshop that covers mainly modelling and texturing, but goes over a little lookdev as well with Vray, I've rendered this with Vray GPU on 2X rtx titans, hope you like it! more renders and context in the link https://www.artstation.com/artwork/OG5PWK
ID:	1203616​a better preview
      I can't comprehend how long it would take to create those textures. Any tips? Question, is the door being cracked to revel the sliver of light to bring the viewers attention to the door? Just wondering.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        My advice is having solid uv's, because whatever you neglect in UV stage, will bite you when texturing, especially when covering large surface areas, with many udims! In the beginning when I was making the workshop I only had the two lit lanterns on the sides, but since you were looking between them anyway kinda, it was balanced, but then I decided to make the clockface lit glass instead of metal sheet, so suddenly your eyes would move in a triangle lantern-clock-lantern, so some light at the bottom kinda balances it a bit, plus makes the place look inhabited, and more mysterious, as the door can be percieved as "inviting" or "unsettling" because it's open a bit. hope that helps!
          hi may I know what is solid uv mean?
          Jackie Teh
          3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
          AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
          Website: https://www.sporadicstudio.com
          Email: info@sporadicstudio.com
          YouTube: https://www.youtube.com/c/SporadicStudio
            Solid is a colloquial way of saying, in this context, 'very good' or 'great'
