Mountain House
  • Mountain House
    I have ten of these homes, this being the second to last. I had a fun time using AI, but I tried to use it subtly. There are some issues, and looking closely, you can tell where the AI was used, but overall, I think it improved the image from the final raw with standard color grading. The most significant improvement, in my opinion, is the foreground ground cover. Otherwise, that would have taken a ton of time to pull off. What Stable Diffusion failed at Krea did an excellent job at, like that foreground ground cover.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Very nice...looks seamless.
      It looks really good and the AI definitely improves it...all very natural. It might benefit from having a little more space around the edges but it still works and is a great job regardless
      There is something a little odd going on with the left side wall....a blocky area in the shadow. Also the eaves beam sticks overshoots a bit on the left.
        Looks great!
        There is something wrong with the shadows on the left, seems to be an issue with rendering. Other than that, it is flawless
        What is your render time?
        Best,
        Muhammed
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          Yes, that has to be fixed. I am not sure.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Originally posted by Muhammed_Hamed View Post
            Looks great!
            Best,
            Muhammed
            I let it render for an hour using a progressive with one machine. Letting it render until done with buckets on two machines takes 3 hours. It is clean enough in one hour for me.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Is that coming from the tree transparency, are those proxies?
              https://www.artstation.com/damaggio
                I don't understand your question
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  These in the ground Booby, look like the shader transparency is not being fully calculated, everything else in the image look perfect.
                    I'll look at the pre-AI and see how it is rendered.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
