Nice. I agree wtih percy that you might want to add accent lighting at each table.
As for holding up the stairs, you can do it with steel inside each step and some massive steel work behind the stone wall. My firm (on the architecture side) did the exact same thing recently in a house in Brentwood.
My only crit apart from the above mentioned is the stone wall map with a rather strange scale (made of pebbles?), and the fact that it has been turned upside down.
Crit on modelling:
I saw the chair model has a little problem with the leg overlapping the sitting body (look the 1st chair in the lower left corner - facing back, and blue one again the 1st close to the squared table.
Crit on design:
I would go for a rectangular look on the columns... IMO..
