not sure what is causing the following two things in the image, so I am hoping for some help.
1 these two downlighters have the same materials attached as all the others. I also have a hdri in the reflection slot of the VRay render dialog box under Enviroment. So I don't know why it is turning out black.
2 I used irradiance map for the first bounce and light cache for the second bounce. I also applied a max camera correction modifier to the camera. Would that be the cause of the "dirty" ceiling"
Lastly what can I try to have my ceiling render more white, it has a white VRay material applied to it at present.
Thanks
Thanks
