WIP - need some help with render times
  • #16
    Laurent - that looks much better already. thanks. yeah the materials definitely need some attention. It is a WIP so I have some time there but wanted to get lighting sorted a bit more. The original is lacking the contrast that I wanted. I'll see if I can duplicate your result in VIZ 2005 thanks again.
    Clifton - that would be awesome if I could reduce by 3x. I'll give that tut a try and let everyone know how it worked out. thanks.
    Again thanks to everyone for all the help. I will post updates as I get time to play around with the suggestions.
    Regards PEter.
    • #17
      Laurent - what kind of photometric lights are you using there? I don't think that is a standard light, from your wireframe - did you use a web light and load an ies file?
      Did you add any reflection or anything to the floor? It looks a little glossy. What were the rendertimes like? Thanks
      Regards Peter.
