school
  • school
    Working on this project.....would be good to have any comments for improvement. Hope to use onyx trees if I get them working well for me...still have not had much time to study them!
    good start, looks very washed out, i realise it is supposed to be a cloudy day but it just looks flat
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      What would you suggest for this? I am using an HDRI environment, a sphere vray light set at 1,0 and Linear Multiply left at Dark 1,0 and Bright 1,0. Should I work with the contrast numbers under Irradiance map?
        I would try to add a sun to get more definition. you could try to rotate your hdri to get more reflection in the glass I guess. I would avoid the prurple/pink cars in the foreground though.
          That's what colorblindess can do to you!!!!
            Tried working on the contrast here...changing also the sky. Any ideas why this reflection is burnt out?
              Arrrgh,
              what the hell is this for carcollors... brrrr
              for the rest, more sunlight a slightly morningbreeze, some bees and the smell of summer...
