Does anyone know what is causing the strange lighting effect in this image (where the ceiling meets the wall)? It's a frame from an animation, using a pre-calculated irradience map.
Are you talking about the light leaks? If so, check on the < Check sample visibility > and see if that helps.
If not, try putting some object obove the ceiling to block surely the light.
so we dont get to see a final? are we not worthy enough? ;P hehehe
