nice,
but i guess the sun could be a littlebit stronger since the sky very clear.
if you see the below part without seeing the sky, it feels like you are in indoor area. but hey, that's my comment only.
yep....it needs a little more stronger light...anyway there is a quite tall building on the right side of the courtyard and the camera is located in the shadow area...ive set one rendering now....will have an updated view on monday morning...
yo thanks for replies....the plants are combination of xfrog and onyx...unfortunatelly the render got a bit funky over night so i have to get it going again today...what are your usual settings for the sun guys when using LWF?
I have used environment at 1.0 and sun(vraylight sphere) at 0.6 in that image....but it turns out dim ...so what do you suggest?
Why not turn the sun coming from above the camera - just the opposite direction... If not in fight with the real N (north) position.
Would gain much more depth and contrast, etc.
the environment is yet to be sorted out...once ill put some nice sky reflection in it should do the trick with the window reflections...im trying different setting now ...i will post asap..
