Gamma 2.2 question
  • Gamma 2.2 question
    I do not quite understand how this gamma correction needs to be dealt with after it has been saved. I have gamma 2.2 and the input 2.2 set in max then i save the render. What am i suppose to do with it to get the proper result, It is also a little washed out... what to do?
    dutchie, what is happening is you are double gamma corecting the image. Try using the VRayVFB then you will get the correct result.
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
