WIP - Hotel and Private clinic
  • WIP - Hotel and Private clinic
    Working on this one now...sent it to the client for comments before rendering final version. Any comments?
    nice work!
    the tree trunk & branch needs a bit more texturing i think... maybe more bump maps
    that stone texture along the building edges.... mind sharing how did u do it?
    Harry G
      I'll have to add some bump maps there. The stone texture on the angles is just a bitmap I made in photoshop giving it opacity. Each angle has a rectangular plane with the opacity mapped image.
        Nice work Chris. The only real problem I see are a couple of the trees, and of course, the RPC people.
        "Why can't I build a dirigible with my mind?"
          Looking good. The leaves and bark on some of the trees look like they could use some more defined textures.
          Mike Henry
          http://mhenry.cgsociety.org/gallery/
            You know, I like using the Got3d people, but when the rendering is at high resolution you can see that they are computer generated, and I then receive comments from the clients. As for the leaves...they are all textured map....maybe I need to pick another texture? Actually the bark is textured also....I guess not done well enough! Have not yet heard comments from the client.
              Aaron....which trees? I'm not too sure about the tree along the path in front of the clinic (second image). I wanted something very transparent though, to not block too much of the view.
                In the first image I think the shrubs lining the sidewalk and the the tall shrubs in front of the building are unusually dark. And on the second image, its just that one scrawny Acer Saccarum y2 (I'm guessing) in the middle next to the sidewalk.
