Here is the tower scene setup. I have a greebled box standing in for the tower. As I mentioned earlier, I didn't spend much time tweaking the render settings. I used the default irmap+qmc with the preset medium-animation setting.
I have a separate VRaySky map for the background and environment. That way I can boost the background multiplier to suit my taste. I think I've got it bumped up to 4. The environment multiplier is set at 1.
The scene is set up using linear color mapping, but I've been getting nice results with exponential too. I just have to adjust the background sky multiplier if I use exponential.
shhhhhh DONT say "Tower" Da_Elf mite hear you and you dont wana go there...
-dave
Cheers,
-dave
■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
i did think it. however i didnt bother mentioning it. i could post some old images if you want hehehe
oh please no no, I was only kidding, realy, it wont happen again I promise, please no
Cheers,
-dave
ok daforce i will try twose two options and post the results.
Did you manage to solve the problem?
Im thinking that maybe rendering exteriors with lots of glass and metals AND vray sun is impossible as it will cause white dots nomatterwhat. If we can make the sun invisible we'll lose all the reflections on the objects, which is not good either. Any solution to that?
So does it boil down to 2 things?
Either no usage of filters with negative values in the weights' curves, or color clamping to 8bpc?
I have never had this kind of issues so far, tbh, with qmc aa, as for speed i always keep filtering off...
Lele
Either with clamping and/or no usage of filters, white dots appear.
